Old 05-01-2014, 04:30 AM   #1
Gilles
twisting arc
Hello JFP,
There are supposed to be No free play when you twisting from the left to the right, am I correct?
Perhaps if I had someone helping me by holding the new flywheel, IT MAY have gone the 15mm to the left but then when you tried twisting to the right, first you go through 15-20mm of free play Before hou start feeling pressure (for 5mm+) that I was able to accomplish by myself...
The issue that concerns me the most, is the fact that the flywheel has the 15-20mm of play between (where) you can twist it to the left or to the right.
Is this extra play in between normal..?
Thank you in advance for your comments!
Regards, Gilles
