Old 05-01-2014, 05:11 AM   #18
piersman
In my experience the smoke that is emitted from these engines when cornering IS NOT the fault of a scavenge pump. I see this condition routinely and have only had a scavenge pump replacement dove it in the instances where a scavenge pump has failed.
Hi Jake , thanks for your comments. You said the above before going on to explain the impact of a pump being seized by engine parts.
What is(are) the cause(s) of cornering smoke that you've found? Something on my car is causing the AOS to suck up and throw large amounts of oil into the engine when 'pressing on' , particularly if having just exited a left hander.
What oil do you recommend? The AOS is 3 months old.
piersman is offline   Reply With Quote
