Old 04-30-2014, 01:50 PM   #7
shadrach74
Originally Posted by lkchris View Post
Codes are often set downstream of the actual problem.
Unless the CAT is broken up and rattling it would be the last thing I'd suspect.
A CAT can't do it's job if the "mixture" it receives is off. When it can't do its job the code sets, but the problem is the mixture, not the CAT.
Really? I've seen plenty of Cats that cease to function without rattling. I destroyed the Cat on a Lex LS 400 limping home on 4cyl. That car had 1 coil per bank and when I lost a coil the raw fuel fried the Cat. Didn't rattle a bit. Bad cats on the 3.2 with <100,000miles is not terribly uncommon in my experience.
As an aside, if you had under 80,000 miles, I think the manufacturer would have to replace under warranty.
shadrach74 is offline   Reply With Quote
