Originally Posted by healthservices
Replacing mine helped but I'm still at a loss as to why as the pump looked perfectly good in every way. Yes the pumps can be replaced with the motor in the car.
Yes I had problems with the site too yesterday.
Hi HS, did you ever get an answer as to why your oil in the head wasn't draining back down to the sump with the car at rest? There was a discussion on one of your threads where the question was raised but the answer was never clear. I can understand that a small'ish amount of oil will always remain in the head but your engine seemed to have a lot in the effected side based on the pictures you posted. Shouldn't that have drained back to the sump (albeit slowly) once the engine was turned off?
I ask because I can see me taking the rear scavenge pump off this weekend and being covered in oil as it pours out the hole from behind the pump!
Cheers
