Old 04-29-2014, 12:26 PM   #1
korbeck
korbeck's Avatar
Low RPM/Gear Engagement Squeak Noise
Hi y'all.
Another weird question here. Recently when coming to a stop and engaging the clutch with little to no gas I hear a squeaking noise until I accelerate.
This weekend I plan on removing the engine cover for the first time to check the belt, bearings, and water pump for drained fluid through the weep hole, although I haven't had to top off the fluid.
Any other suggestions, or ideas? It's like a weird squeaking noise until I give it a little gas or until I go. Happens on second gear to when rolling at a low RPM engagement. It also happens sometimes coming to a stop in neutral.
It also doesn't happen when driving from a cold engine. It happens mostly when the engine is warmed up a few minutes later.
I'm really suspecting the bearings and hopefully WD40 will help
Also what type of belt would I need if that is the problem, although I don't see how it could make that type of noise at low RPM.
Thank you for your patience and advice. It's a bit annoying to drive in stop and go Atlanta traffic constantly hearing that rhythmic eee-eee-eee noise 😂.
Also, I replaces my AOS last year November and my car has about 76k.
Thank you!
korbeck is offline   Reply With Quote
