Old 04-24-2014, 12:11 PM   #1
RaisedOnPorsches
I just installed one of these (TranzIt BLU w/o RCA plug adapters) in my 993. The 993 has a CR-1 which is even more limited for connectivity options than the CDR-220. I have the TranzIt BLU connected between my FM antenna and the receiver/head unit. The sound quality is pretty good. I'd expect it to be even better with the RCA to AUX output (pure digital input to output rather than digital input to analog output).
The phone syncs right up once you have the app installed. The only issue I've had was when two different devices had the app and tried to pair with the transponder.
I installed the on-off switch because I had a hole that needed filling, but otherwise, I wouldn't bother with that feature. Just make sure to splice the 12v power line to into a ignition switch toggling 12v line and not the constant 12v line. (Otherwise you'll be draining your battery unnecessarily when the car is parked.)
In summary, I'm very pleased with the TranzIt BLU setup and would recommend it to others.
RaisedOnPorsches is offline   Reply With Quote
