If the motor mount was the cause for difficult shifting when the motor is running, wouldn't it also interfere with shifting when the motor is not running?
As and additional test, however, I jacked the car up and placed wood blocks under the front engine mount and lowered the car onto the wood blocks, thinking that would take weight off the mount, and still with the motor running, it would not go into gear. With the motor off, it will. That is why I discounted the idea of the motor mount causing this problem.
