Originally Posted by particlewave
The only reason I settle for the hd foam was to fight the 'fitting' issue. Tried some rubber seal but I just couldn't get the thing to 'squeeze' enough to fit the headlight in place. Those are normally industrial stiff :/ Tried smaller rubber seal but then.... worked just fine but no seal, water would have gone inside the fender like in the Niagara falls.
The HD foam made the fit so (too) easy, tight squeeze, perfect seal, no water and all but again.... not sure if the stuff will last years. I'm thinking NOT but we just never know
