Old 04-23-2014, 12:08 PM   #2
Xcellr8
Bleed clutch with Motive Pressure bleeder what is next?
Geez, can't believe I been fooling around with this for so long. Finally, got around to bleeding the clutch properly. That was an ordeal in itself, but believe I finally got it.
Problem is, still can't shift gears when car is running and on the ground.
Is there a way to test the slave cylinder to see if it is functioning?
I can move the shifter towards each gear, and hear movement in the back, so I believe the shifter cables are trying to go the right places. Still, I'd like to "know" that its not the front motor mount that is keeping the cables from moving adequately to engage the gears. Can I jack up the front of the motor to simulate a new motor mount?
Any ideas? Thanks, Joe
Xcellr8 is offline   Reply With Quote
