Originally Posted by Jake Raby
There's a pair of seals inside some of the servo units. To gain access to them the unit must be cut open. When they start to fail the material will contaminate the oil.
Thank you Raby-Wan Kenobe! What are the implications of the failure of said seal? Could you provide a bit more insight as to what I do to remedy the situation? Do I need to replace the whole VarioCam unit?
