Old 04-21-2014, 03:23 PM   #3
Gilles
In my experience by the time a DMF unit needs to be resurfaced its very near maximum deflection of the two masses and should be replaced anyway. Kinda like putting lipstick on a pig to resurface one.
Jake,
Would you recommend re-surfacing and then balancing a 'New" DMFW..?
This is to remove some of the inertial weight (not quite like a LWFW), but end up with a lighter than a standard dual mass flywheel.
Your comments are always appreciated, thank you.
