I've had a squeaky clutch noise for 5-6 years on mine. '00S w/43k. I've tried removing the slave cylinder and greasing the end of the little plunger thing. It didn't work. It's kind of a "springy" sounding squeak when I let out on the clutch pedal. It's in the clutch area as opposed to at the pedal itself. You'll see both areas posted as making noise on this forum. It almost sounds as though something has "dried" out. The clutch works ok though. Does your clutch work ok? Or does it feel stiff?
