Old 04-20-2014, 12:43 AM   #15
healthservices
Registered Boxster abuser
healthservices's Avatar
Well with hot spots such as those shown if one were to reuse, it would be best to grind it. Hot spots are pretty hard, a cutting bit would have a hard time cutting threw a hot (harden) spot. A good fly wheel resurfacer can tell you if it is even recommended to try to reuse it at all.
Please note not many machine shops can grind a Dual mass flywheel please asked.
If I saw hot spots such as these on a brake rotor I would toss it.
If you are the type that believes brake rotors can or should be resurfaced for new brake pads you should consider resurfacing a flywheel when a new clutch is installed.
A flywheel with a bad surface can make it hard to launch a car smoothly in stop and go traffic.
