Both marks point in OR both point out, depending on whether you are at TDC or at TDC exhaust. Bentley's and 101 Projects books are not clear on this.
If you plan to pull off both sets of cams at the same time, I can recommend using the procedure outlined in Porsche 986 Boxster Workshop manuals available in electronic version.
Another tip for dummies: the engine rotates clockwise when you are looking at it from the pulley side. It is much easier to rotate if you pull the spark plugs.
More tips for dummies coming soon!
