Old 04-18-2014, 06:22 AM   #10
Mark_T
Dont try to suck the old fluid out of the reservoir.. Just use the power bleeder and pump the old fluid out of the reservoir. watch the resrvoir until its almost empty, then add brake fluid and bleed.
Agreed. Excellent suggestion. I'll just add that if you don't plan on bleeding the clutch, be careful how low you let the master cylinder go. The outlet for the clutch is on the side, not the bottom like the brake line.
'99 black 986
