Old 04-17-2014, 04:41 PM   #8
Timco
I am my own mechanic....
Timco's Avatar
Originally Posted by rp17 View Post
Timco, there is a proper break in procedure for new pads on a old rotor. It consist of driving in a open parking lot at various speeds and slowing down to about 5mph BUT not coming to a complete stop. Heating up the pads and rotors to prevent thermal shock but ultimately leaving a thin layer of brake pad material on the rotors. Bedding in the pads I think its called. Perhaps someone else can point you in the right direction. If not, I think I have the pdf at home.
Also are you using the anti squeal pad inserts that stick to the back of the pads? Just asking because not everyone uses this.
There are discs that seem to be glued or attached to the pistons of the calipers. No other parts or grease or glue.
'08 VW Touareg T-3 wife's car
