Old 04-17-2014, 12:28 PM   #4
rp17
rp17's Avatar
Question is, where do I find the proper break in procedure? Is there any chance I damaged the rotors? Shiny, new, flat. Seem perfect, no discoloration. The squeak is always right at that perfect soft breaking point when you drift to a stop. Anything less or more and it's silent.
I have never used any brake sprays or that pad grease. Am I missing something??
THANK YOU!!!!!!!!
Timco, there is a proper break in procedure for new pads on a old rotor. It consist of driving in a open parking lot at various speeds and slowing down to about 5mph BUT not coming to a complete stop. Heating up the pads and rotors to prevent thermal shock but ultimately leaving a thin layer of brake pad material on the rotors. Bedding in the pads I think its called. Perhaps someone else can point you in the right direction. If not, I think I have the pdf at home.
Also are you using the anti squeal pad inserts that stick to the back of the pads? Just asking because not everyone uses this.
