Thread: Batteries..
Old 04-14-2014, 09:20 PM   #2
Timco
I am my own mechanic....
Timco's Avatar
I am a registered batteryholic.
I currently have:
7 yr old stock Bosch battery that still holds a charge 40 lbs $120ish
Deka motorsport AGM battery- 17 lbs $89
Odyssey PC680 AGM battery- 15 lbs $114
Shorai LFX36 Lithium Iron battery- 5 lbs- $300
All batteries start the car easily. The lead acid Bosch is the least vulnerable to overcharging and has by far the best reserve power. The 2 AGM are in the middle with the Deka offering better starting amps. The Shorai requires special care and feeding with a proprietary charging system. It is very light and works well. Pick your poison.
35 lb difference is huge. That's more than the rear cat delete savings or about what the spare weighs! Seems worth the cost.
'08 VW Touareg T-3 wife's car
