Old 04-14-2014, 10:17 AM   #2
evo-r
evo-r's Avatar
Originally Posted by woodsman View Post
Why do you say 'you know your springs and shocks are good'? What's the mileage on both cars?
Based from what I've observed, no leak on struts Boxster: 81k miles, TDI: 31k miles
are those front tire pressures hot or cold? if hot then you should be around 36 psi front - you might be rolling onto your sidewalks - chalk your tires and see what happens.
if cold then perhaps too hard; oem is 29 for the front I think - check front tire wear and see if you are wearing the middle of the tires more than this sides.
Cold pressure and I bumpped up the front because my new front tires are 225 vs stock 205.
I'll need to have a good look at all the bushings.
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
