Old 04-14-2014, 09:11 AM   #1
The Radium King
The Radium King's Avatar
are those front tire pressures hot or cold? if hot then you should be around 36 psi front - you might be rolling onto your sidewalks - chalk your tires and see what happens.
if cold then perhaps too hard; oem is 29 for the front I think - check front tire wear and see if you are wearing the middle of the tires more than this sides.
