Old 04-14-2014, 08:21 AM   #12
Benjamin
Benjamin's Avatar
Originally Posted by cnavarro View Post
Just be sure that you drop the oil pan and clean everything out if you haven't already. I'd also recommend running a flush oil for a very short period. Installation of a spin on filter adapter will prevent debris from being re-introduced to the engine after it gets in the filter. Doing all of this will give you your best chances.
Thanks Charles, I have dropped the pan and cleaned everything out. I just ordered some Drei Bond to seal it back up and it should be here on Thursday. I like your idea of running a flush oil. I have a case of DT40 that I was going to put in to replace the Mobil 1 that was in it. I may just hang on to the DT40 and get some more Mobil 1 and run it for a short period and then drain. I have a few filters on hand, but they are the stock type. Can you explain to me why the spin on is better? The OEM version is much easier to inspect after an oil change.
Benjamin
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
