Old 04-09-2014, 11:00 AM   #16
Burg Boxster
Before I give you an answer to each individual question I will generically state you will be much better off and happier by just pulling out existing garbage Porsche put in as a sound system. Particularly so since you are experiencing problems w/ the system.
Originally Posted by Blankman View Post
Will the cdc issue mean that the denison unit wouldn't be recognised?
It most likely will be an issue as the CDR23 recognizes the Dension unit as a CDC
Say i get everything working will both the denison unit & cdc both work or does the denison replace the cdc?
Desnion replaces the CDC BUT there is an override switch w/ the Dension to allow it to act as a passthru. Would you really still use CDs if you had ipod hook-up?
What is the sound quality like with the denison?
basically same as any other MP3/ipod hook up device. Not spectacular but acceptable.
Has anyone installed the Bluetooth denison?
Seems fruitless in a convertible but it has been done.
Being a rookie Porsche owner I have lots to discover, I'm sure a lot of self discovery but hopefully a little help from you guys. Much appreciated.
Again, you're better off just going after-market w/ a system that includes iPod/Phone integration, Nav, Bluetooth, etc.
Good luck!
"Cool Prius!"
- Nobody
