Originally Posted by kindlethespirit
Thank you. They just did the oil change a few hundred miles ago and put in 9.5 quarts, so not sure what is going on.
I think 9.5 qts is a little too much. I would suggest you drain some. Check your manual to see what your capacity is. Overfilled oil causes AOS failures.
