Old 04-08-2014, 08:28 AM   #3
hancock1701
I did my ~$50 ebay short shifter install.
It looks identical to the B&M unit for $295.
I found that I had to modify it a bit so it could reach full throw.
I had to grind a bit of aluminum off the bottom where it interferes with the plastic frame and I also had to grind a bit of plastic off the frame to clear the pivot bolt.
I also ground the pivot bolt where it protrudes past the nut.
I don't like the slop in the pivot bolt but I'll drive it first to see if I like the results overall, and if so I'll take it apart again and put some proper metal spacers and some teflon washers to remove the slop.
I also found about $20 in coins when I removed all the console parts, that will lighten the car considerably
That's exactly what I did to my cheap one as well. The front bolt was hitting the plastic frame, but it's fine. I added a few rubber and metal spacers to reduce that side to side sloppiness, and it is much tighter now.
hancock1701 is offline   Reply With Quote
