Old 04-07-2014, 10:39 PM   #23
healthservices
Registered Boxster abuser
healthservices's Avatar
A simple bolt, a couple of washers and a couple nuts will get out even the worse glued in ones. I made it because the transom plug idea does not work for the super stuck tubes.
Simple yet effective...
Attachment 18071
Stick the bolt in so the washer catches the inside lip...
and use a screw driver or other prying device to pop out
Took longer to post this than it was to pull out the tube using this method
Sent from my SAMSUNG-SGH-I317 using Tapatalk
