Thread: Cooling Fans
Old 04-07-2014, 03:46 PM   #2
Steve Tinker
Steve Tinker's Avatar
I don't believe what the dealer has told you is correct.
Both fans run in parallel which means they both switch on & off together. They also have a low and high speed setting, so if the coolant temp reaches +/- 102 deg (I think) the low speed fans kick in, with the high speed kicking in at +/- 110 deg (I think).
The easiest way to check fan operation is to switch on your air con - both fans should operate in the low speed setting. If they don't, you have a problem with the fan motors, wiring, relays, fuses or ballast resistors which control the low / high fan speed.
Use the search function at the top of the page - type in cooling fans and read on....
2001 MV Agusta F4.
