Thread: Cooling Fans
Old 04-07-2014, 01:31 PM   #1
Vizen2
Cooling Fans
I've just taken delivery of a 2000 Boxster S and am not sure the radiator cooling fans are working correctly, when the car is left idling the right hand radiator fan cuts in, but not the left hand fan. The supplying dealer tells me "the second fan does not kick in until the water temperature reaches near to 100 degrees. This means when you think it’s not working it actually is, but the engine hasn’t got up to temperature. Up to 100 degrees the main fan will kick in and under normal driving circumstances the engine will remain at around 80 to 90 degrees, being cooled by the main radiator. If stood still in traffic for long periods allowing the temperature to raise from its normal operating temperature, the second fan then kicks in to support the main radiator in cooling"
Could anyone confirm this correct, the right hand fan cuts in first then if the temperature does not come down enough the left hand fan cuts in, sounds feasible, but just wanted confirmation, thanks in advance.
Vizen2 is offline   Reply With Quote
