					Originally Posted by  Mark_T
				Now I'm confused. You said "and my favorite...... Open and close unlatched top by turning the key in the door (in tandem with rolling up and down the windows) "
In order to implement this feature you must obviously know that you can control the windows via the key, right? Am I missing something or are you just funning around?
Further to that, would this unit be available without this feature? I sometimes use the key to raise or lower the windows, but I don't necessarily want the top operating at the same time.
I only knew of being able to put the key in the door and turning it to open and close the window. I never knew it was possible remotely through the key.
I can definitely provide you guys with a relay that doesn't have this feature installed if that's what you prefer.
