[QUOTE=Benjamin;394486] as you can see there is a blue/green substance on the mating surface that I think may have been sticking the two parts together. I don't know if it is supposed to be there or just something done in a previous repair./QUOTE]
It may be loctite applied too generously on the bolts and it seeped into the area between the flanges.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
