Originally Posted by rfuerst911sc
My 02 S is my first convertible. I have read on this forum and others all about the maintenance items for the plastic rear window. My question is what do you use day to day to clean the outside of the window ? Dust, road grime, pollen and just everyday stuff what do you use ?
I use Plexus. Got it at the marine supply store. A bit expensive, but you don't use much, so the can lasts a long time. I've had mine for 7 years, and the can still feels full. My rear window looks pretty good for being 14 years old. Plexus has plastisizers in it that help keep the plastic window from hardening and getting brittle.
http://www.plexusplasticcleaner.com/plexus.html
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
