Old 04-06-2014, 06:22 AM   #2
mgfranz
Does the clutch work? From your description I'm unsure.
When you push the clutch in does the trans disengage?
Wild guess...clutch throw out arm/bearing.
The clutch does not work. I have full pedal motion, no sticking and it even feels like it has normal pressure, I just can't engage any gear. Like I said, I was able to drive it when I put in second and started it.
Cables... ? I wasn't aware there were any cables? This sounds interesting, can I do a visual to verify? Diagram? Never mind, I just found a great write-up over at rennlist.
I'm trying to rule out the clutch/pressure plate for now since the vehicle drives fine when in gear.
mgfranz is offline   Reply With Quote
