Old 04-05-2014, 11:52 PM   #127
Shehadehd
Shehadehd's Avatar
Originally Posted by Coaster View Post
Very cool, quick question just so I understand. If you have the rear Bose you can only see the engine with this cover when the top is up (thru the back window)?
With the rear speakers, you can kinda see the engine from inside the car if the top is up. But it's mostly like you said, it is visible through the back window. The rear speaker deck has a small curve to it so I'm still working on making a nice looking intermediate carpet that it will sit on when it locks into the engine cover.
As for how easy it is to clean, I haven't had to clean the inside of the top at all since I sprayed it with anti static solution. The outside of the top (the side the touches the soft top) needs to be wiped with a microfiber like once a month. Also, my engine block has also remained pretty clean since the first time I sprayed it down in January. However, this may just be because I'm in the bay area and there's not much dust here?
Shehadehd is offline   Reply With Quote
