Old 04-03-2014, 09:30 AM   #1
drjoe
hmmm... i assumed the daylight running bulbs were the same as the regular headlamps, and that the problem was not the bulbs, but from reading other threads, it sounds like there are 3 distinct bulbs -- daylight running, regular, and high beam (not to mention the fog lights).
both regular lamps are out, so it sounds like it could be the bulbs, the switch, or the fuse.
aside from finding the fuse and checking it (where?), is there a trick to tracing the problem to the switch vs. bulb? i read something about maybe the lights coming on during ignition independent of the switch, meaning that would test the bulbs?
drjoe is offline   Reply With Quote
