I would probably try cleaning the MAF and then reset codes if present. I think that if you undo the battery the MAF will reset and 'relearn' baseline setting. No mechanic but it sounds like the computer is having trouble getting the cold air mix correct.
'01 Boxster S - Silver/Gray
'58 356A Cab - Fjord Green/tan
