Old 03-31-2014, 06:02 PM   #18
Jamesp
Beginner
Jamesp's Avatar
Made my new order to ECS today. New AOS, new chains ( see, I [U]am[U] listening), and new ATF filter and gasket. I've decided to take JFP's advice and change all the ATF. I need to find the proper fluid here in the northern hinterland (Montreal). Any suggestions are appreciated.
There are so many things that could/should be done, but the shopping list is getting long and I need to practice a bit of austerity!
I will post my experiences and pix if ever I get this mother back in place.
Do you realize you need to split the engine case to install new chains? At that point go for new main, thrust, and rod bearings, as well as new rod bolts. Rings would be nice, but at ~$1200 the old ones look pretty good.
2003 S manual
