Thread: Boxster window
Old 03-31-2014, 07:58 AM   #1
srborthwick
Boxster window
I have a 1999 Boxster 2.7. Two problems. When I travel over a bump the drivers window drops by 1/4" and the interior light comes on. Often is corrects within a second and returns to normal. The drivers door window only drops 1/4" when parked if I slightly operate the door pull in/out to lower the window and it will not remain down un less I hold it manually. To close the door I must then hold the pull slightly the slam the door then the window returns to top.
Is the fault of a faulty 'Door handle microswitch' 996 613 12600?
srborthwick is offline   Reply With Quote
