Old 03-30-2014, 10:18 AM   #11
qwerty
To put the belt on you have to loosen the tensioner by turning it clockwise about 45-90 degrees. If it freely turns and tension does not slack then reach behind with a 15 mm wrench and hold the nut in place while you tighten the tensioner. Then try again 45-90 degrees clock wise. Install the lower idler/tensioner last I think. The belts should not change with heat and should be the same length.
qwerty is offline   Reply With Quote
