You can buy replacement clips, and you should. That's 99% of the rattle problem.
For the other 1%, I put some thin foam tape along the bottom of the plastic windscreen so it sits a tad higher in the groove and it doesn't rattle any more. Give that a try.
Be very careful removing your windscreen... if the frame bits snap off, the thing is toast.
