Old 03-28-2014, 09:01 AM   #1
JFP in PA
The AOS hasn't given me any grief so far but it is very easy to change it with the motor out. Is this considered a standard maintenance item?
JFP, I'm a little apprehensive about the transmission fluid: can I just drain it all from the drain plug or will I get a bloody mess when I open it up?
Can I use any LT71141 spec. transmission fluid ?
You will only get about 3-4 liters of the total 9+ liters in the transmission by draining the pan; most of the fluid is held in the converter.
You need to use a fluid whose specs match Porsche's for your car.
