Old 03-27-2014, 03:01 PM   #7
rfuerst911sc
I'll chime in as I have these in my new to me 2002 S. Yes they are overly complicated for what they are. I had to remove mine because the drivers side was pushed in past the face plate. Turns out the " cage " that holds the cup holder allowed it to slip past the stops. I spot caulked with an adhesive caulk to stop the sliding. Then I had to repair the top of both cup holders because apparently the heat from the dash, the heat/cold from the dash vents make the plastic brittle. Got that fixed then found out almost every decent insulated coffee mug won't fit the damn thing ! Yes you can find mugs that will fit but then the next problem, if you have the AC on your hot coffee quickly cools.........stupid design. Oh and if your mug/soda/drink spills it runs down on your electronic items below.........stupid design. Today I received the two ultimate cupholders I ordered on Monday. They are cheaper than this overly complex POS and place your drinks low on the floor where they should be in my opinion.
rfuerst911sc is offline   Reply With Quote
