Thread: Crying Engine
Old 03-27-2014, 05:53 AM   #17
kk2002s
kk2002s's Avatar
I suspect that if you are taking your car in to have a mechanic re secure some floppy under panels, then you are not comfortable doing the engine repairs.
If this is the first time you have noticed oil leakage, haven't noticed drips where you park, then you must not be leaking much.
Are you checking dip stick level regularly?
If the car is not losing a lot then cleaning it up and monitoring could save you thousands
Correct - spending $3k to save $15k is probably worth it
BUT spending $3k to fix a $100-$500 DIY job is _ _ _ _ ? fill in your own words
Seal Grey
