Old 03-25-2014, 11:51 AM   #13
Brad Roberts
Brad Roberts's Avatar
In this next pic, You can see the actual "splines/threads" (they are not threads)
This is a male/female deal. The plastic piece attached to the shifter is "female" and the cable end is "male".
You can unsnap the cable end and cheat it forwards or backwards on those splines.
What JFP was explaining is a factory tool that we snap down into place to hold the shifter in a "neutral" position, and while the trans is in neutral, you can drop the cables into these plastic male/female receivers.
I like to "cheat" the shifter one way or the other from what the factory "suggests" by using their tool (I cheat them towards the driver so 4th-5th is easier to hit with the 5 speeds, and so 5th gear is not up under the dash on the passenger side)
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
