Its possible that your window regulator has broken. After the window has dropped, open the door and see if its easy to move the window by hand. If so. then the regulator is the likely cause. On the other hand, a 2" drop is characteristic of opening the convertible top latch. One would expect the drop on both sides not just the driver's. Perhaps a sensor has gone bad.
