Old 03-24-2014, 06:22 PM   #2
KevinH1990
KevinH1990's Avatar
Originally Posted by Ckrikos View Post
I read that you need to pull the hvac harness out from the passenger side, but that was impossible. I ran it down the drivers side and got it to work but its very tight. I wrapped it in a plastic wire tube to protect it from some sharp edges on the lower console given how tight it was. Otherwise it turned out well.
That is what I heard too. I will keep in mind that I may need to try the driver's side.
My technique for performing DIY projects on the Boxster is to read everything I can, take notes and plan each step before starting the job. I've also learned to walk away for a few minutes when something isn't going right. There seem to be several places where this will get difficult. I'll probably need to meditate before I start this job so that I don't get frustrated and break something by using too much force.
I've been collecting bookmarks to all the posts where people have done a double-DIN installation. I'll add your tip on the HVAC to my collection.
