Old 03-24-2014, 03:28 PM   #10
Brad Roberts
Brad Roberts's Avatar
It's a starting number, the final number comes out after the corner weights. Me giving you numbers won't help you
We run ride height XX because of the bump steer in these cars. Run them super low? bad bump numbers. Since we cannot adjust the bump in SPB (like I would in a full monoball car) RAISE the car up until the bump numbers get better Simple.
BoxsterS has less bump gain in the rear due to a change in the casting. They moved the toe link back from axle centerline, which slows the toe gain in bump.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
