Old 03-21-2014, 02:11 PM   #13
onaFLYer
Originally Posted by guzerone View Post
I'm running Boxster rears in the front (18x9 ET52) with 265/35-18 and 996 rears in the back (18x10 ET65) with 285/30-18 using a 20mm spacer. Tires are Potenza S-04.
That's probably the max amount of rubber you can fit without massaging the sheet metal.
I ordered some 23mm spacers for the rear, hopefully not too much. Would never think of running that big of a front tire & wheel. Did you need spacers for the front?
What is the common front spacers used by you guys? 7-10mm I'm guessing?
onaFLYer is offline   Reply With Quote
