Old 03-19-2014, 03:00 PM   #3
desert_porsche
Sounds to me like both engines need need wear pads on the cam adjusters. We see these worn at as little as 35K. These had 30K on them with a female driver, which is the catalyst for this wear in so many cases.
These were resulting in cam deviations of 9 degrees. Of the last 20 IMSR procedures we have done on 5 chain engines, 75% of the engines did not pass my pre-qualification due to excessive cam deviations that were created by these components being worn. We will not carry out an IMSR if cam deviations are in excess of 3 degrees, because the car will set a CEL after our work is done and then we have to explain that the issue was not a result of our work.
The 3 chain engine omitted these completely.
Jake,
When you say female drivers are the "catalyst" for wear, to what are you referring exactly? What is it that females do wrong? So I can be sure I'm not doing the same thing
desert_porsche is offline   Reply With Quote
