Old 03-19-2014, 08:20 AM   #2
notech
notech's Avatar
Originally Posted by danch View Post
If you go in the Frunk (Front Trunk) remove the battery cover & battery (make note of the pos & neg so you put back the correct way round) , then on yours (left hand drive?) on the right hand of the firewall you should see a large rubber grommet, use a stanley knife to slice an X in it & pass the wires through & push them down for about 6 inches.
They should come though above the accelerator peddle & you should be able to feel them
Dan
Thanks! Done it! It was a pain to get the right cables from AMP, also my pinout colors are different. I've found an aperture with a rubber cap that get straight to pedal.
If I put all speakers on common ground would this affect anything?
notech is offline   Reply With Quote
