Originally Posted by Steve Tinker
There is considerable difference in road "feel" between different toe settings. Even with good shocks and suspension bushings, zero toe feels different to (say) - 2 deg.
When I installed my PSS9's, I had a quick alignment done by a non Porsche shop and initially it was OK on the road, except the car got nervous and twitchy over 140kmh. I knew it wasn't caused by worn suspension parts, tyres or shocks - all new.
So I took it to a Porsche specific shop and they gave me the following setup:
FRONT: Toe = 1,5mm, Camber = -0.6 deg, Caster = +7deg.
REAR: Toe = +2.0mm, Camber = -2deg.
Wih the front toe increased from 0 to 1,5mm the nervousness dissapeared and the car now feels really good at all speeds.
And don't forget that the rear alignment has a marked affect on the cars feel too.
I had it set to the factory specs in the shop's database. Either way, had I kept the car, I'd probably be doing the shocks by about now anyway.
To OP Stilov:
I just ordered a set of KW Variant 1 coilovers for my Mini Cooper, and the Cayman Turbo is arriving Friday after next on a set of H&R RSS coilovers. I'll be autocrossing the Mini next weekend and having a trackday in the Cayman the weekend after and can give my take on the highway ride quality and handling of each of those setups at the end of the month.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
