Originally Posted by tomonomics
>>yes but the 03-04's were also the heaviest 986's. And the power bump was not huge.<<
From the online specs, they are only 66 lbs heavier with 8 more HP. Which 'technically' is a better power/weight ratio. Not sure what common options might sway those numbers.
I thought the improved vario-cam performance improved low-RPM response as well. Am I missing something that would make the 2000 S a better performer than the 2003 S?
+66#? Tip??
EDIT:
I have 126# difference between manual 00S vs. 04S.
*1997 Curb weight: 2,756 lbs
2000S Curb weight: 2778 lbs.
2003S Curb weight: 2811 lbs.
20004 Curb weight: 2904 lbs.
for reference, a 996.2 GT3 with AC and steel brakes is 3,152 lbs.
